Exciter wire reading
What did the exciter wire do with the key on and off?
There shouldn't be anything in the wiring that would cause you to get 25 volts at the drivers side alternator. Since it was working fine before and all your 12 volt truck components aren't leaking magic smoke out, lets just ignore the high reading for now because it is probably just me not writting clear enough.
Back to the exciter wire. If it is 0 volts key off and 12.6 volts or so key on, your truck is fine and the problem is with the alternator.
hi barrman, thanks for all the valuable info. I have a question that differs slightly from these other guys. I am not getting voltage to the exciter wire on alt 1 with key on. I checked and my heater blower fuse is good, I cleaned the spades, and the blower fans works nicely, at all speeds. at start up, i am no longer getting my gen 1 light to light up. it was working as of yesterday, but i swapped out my gen 1 with another used one (which was pulled off a running truck some time ago). I pulled the bulb and swapped it out for a known good one. still nothing.
what is my next move?
also, my volt meter in the truck is playing funny games. sometimes it reads in the yellow, about half way, and then the next time i start the truck up, it wont move at all and just sits there. dead.
batteries are full charge, load tested very well.
thanks in advance for any info. my head is spinning trying to absorb all these posts.
MORE INFO. ok, still no gen 1 light. when i started the truck this morning the volt meter was in yellow, low yellow. i went up under the hood, and wiggled the 2 wire plug on the alt 1 and then looked in the cab, the voltage was in the green...i started to think i fixed it somehow.
turned the truck off, got breakfast, came out, turned key on, still no gen 1 light, started up, and then voltage meter was back in the yellow again. i tried the wiggle wire trick, and no luck...still in the yellow.
question: where does the brown tickler wire go from the alt 1? to the fuse panel under my dash? i have been looking at so many diagrams, and i think that is where it goes....does anyone have any ideas? thanks
more info: pulled out the bulb and socket from the gen 1 light, and voila...gen 1 light works now!!! and my guage in dash reads in the yellow and then green. one question is that my guage needle is herky jerky, and not smooth. if i tap the glass it moves. not sure if there is a connection. any ideas? does everyone else's needle jump or does it move smoothly?
