Drock
- 12
- 0
- Eatonton GA
Ah couple quick questions. I did the HMMWV coolant crossover tube swap ah couple days ago. And now the Gen-2 light will stay on until the high idol turns off and I blip the throttle. When I did the swap I had to remove the passenger side upper alternator bracket ,and swing the alt down out of the way. I also had to remove a ground wire from the drivers side alt. Could this be a ground issue? Does the passenger side alt ground off the bracket?
