Globe GTTU202-30-20 T/A Equipment Trailer Wheel Swap
Russ Knight
1,054
Perry, FL
I think I remember Wes telling me you can convert these trailers to dual wheels instead of the massive single wheel and tire setup. Is it possible, and if so does it work well? @simp5782
simp5782
Feo, Fuerte y Formal
9,384
Mason, TN
Globes and load king trailers can run any 10 lug hub pilot civilian wheel
Smallest in 10 lug wheel is a 17.5 and tire you can go is a 215 70 17.5
I ran a 225 70 22.5 which is common low pro and the shortest 22.5 at 36in tall.
Smaller the tires the heavier it is to pull hint as to why they have large tires not just for clearance
The Holden MTO 20s can not run a dual tire setup without swapping hubs as they use the large mrap hub pilot pattern.
