chopperchad
- 0
- 0
- delta ohio
NEED HELP! .. I would like to single out my dually rear end .. I found a description online about how to do this , it looks easy . The problem I have is my drums do not have the 8 bolt center that the hub bolts to. My hub slide thru the drum and uses the wheel studs to connect the drum and hub . The outer flange on the end of axle shaft has the loop on it That shows when you look at wheel . do I need to get different drums ? If so where? Or is there another way to do this ? My hubs are taped on inside to allow this flip .. any help would be greatly appreciated... thanks
