Asmoday
- 0
- 16
- Los Angeles, CA
I was finishing up, putting brackets back on the '09 today and ran into a issue with the passenger side lower alternator bracket. When I went to slide it on the studs it hit the water pump housing. Enough that it was a real issue. This was a brand new AC-Delco pump purchased at the GM dealer. I noticed when I took it out of the box that the casting was beefier than the one I removed.
Nonetheless I had to notch the alternator bracket so that it would slide on the studs and have appropriate clearance.
Just a fyi if anyone happens to run into the same problem...
