Gunfreak25
- 620
- 113
- Yuma, AZ
This is the 2nd time typing this out since I accidentally deleted it. So bear with the lack of enthusiasm in information listed below.
The M211 and M220 trucks use a Bendix AIR PAK model # 2500685
It is unknown if this is the same model used on M135's.
For those who are installing 5 ton rebuild kits in their AIR PAK's we all know by now the only thing the 5 ton kit does not replace are the 2 small control valve piston seal's.
These two control valve piston seals are not the same. They are both installed with the V sealing lips opposite of each other. One seal is for the hydraulic side of the piston and is part number 374272. The other seal is for the air side of the piston and is part number 375833. The difference is the hydraulic seal is made of harder material. These can both be ordered from Brake Systems Inc in oregon.
More research has yielded a page listing ALL the AIR PAK models manufactured by Bendix through the years. It lists the length differences between the models to help you identify exactly which model your truck has.
As I said the M211 and M220 use Bendix 2500685. It appears that Bendix 2500690 is a suitable replacement, just swap the brass fittings over since they are smaller on the model 690.
The Bendix Model 2500690 can be bought from NAPA for $400.
NAPA AUTO PARTS
HERE IS THE LINK TO THE AIR PAK PDF FILE. GO TO PAGE 80 FOR THE INFO.
http://www.precisionrebuilders.com/pdf_catalogs/VacCatalogPHB-0398.pdf
This information came at a good time as it appears Alfa Heaven is now out of AIR PAK's for the GMC's. This is likely indefinitely. Long live GMC's. We'll keep them going one way or another.
NAPA AUTO PARTS
