Goat Update
jfnemt1ff1
Higgins Lake Mi.
Thanks: I am starting to feel a little preasure.After I hook up a little more small parts on the engine,Iam going to up one more coat of paint on. Then it is on to finishing up the wiring and putting it all back together. I hope to be done by mid-april so I could put some some miles on it befor the trip to aberdeen. :D
maddawg308
793
Appomattox, VA
Looks good John, a lot of progress. See guys? Having a garage really helps in the cold weather, you can actually get stuff done on your rigs when its snowing! (unlike my pile under 6 inches of snow for the past month)....;)
JDToumanian
14
Phelan, CA
JDToumanian (Jon) knows his 2-cycle Detroits and I'm sure he can help you if you run into trouble.
Great looking goat! I wouldn't mind owning one of them someday... I do love those old Detroits! I bought my deuce in non-running condition, and if the engine turned out to be junk I was going to put a 4-53 in it. It was bittersweet to discover that it's whistler was in excellent condition...
The goat engine is more than just aluminum head, the entire engine is aluminum. They're a popular engine for 2-stroke nuts to put into pickup trucks because they fit easily and they don't weigh 1,100 lbs like the iron version. I'll be out here watching if you have any trouble, but once you get the air out of the fuel lines, (an outboard motor rubber squeeze bulb from WalMart plumbed to the fuel inlet works great for this) it will probably fire right up. Make sure the "mouse trap" energency shutdown flap is working (it's on the blower housing) Detroit governors can stick and cause a runaway. Remember that if you test the mouse trap, it does not self-reset... You will need to do it manually.
Regards,
Jon
1958 M274
North GA
As far as I know, goats don't have the "mouse trap" air shutoff flapper... If you are ever worried about a run away on startup, start it in high gear, high range with the clutch in. That way you can stall the engine if it starts to run away. Not that that would work in this case since the goat in question isn't fully assembled...
steelsoldiers
4,089
Charleston, WV
When I worked as a roustabout we would have trouble with the diesels in our trucks and rigs running away on natural gas blowing from a well. When that happened, someone would scramble to yank the mushroom off and cover the intake with a board or stuff a jacket in the intake. You could do that too. Just make sure if you test fire it without the air filter housing on, that you don't let something get sucked into the supercharger ;) That goes for any of your long-haired friends and shirt tails too :shock:
