ATPTac
- 4
- 16
- Charlotte, North Carolina
That's exactly why when I go in to do something on these trucks I replace everything within reason. It's not like a car where you can pull the wheel off and have access to everything in a couple minutes, or if once you pull the drum off and see a bad part you can run down the street and grab what you need.Yeah, I figured on doing that. I try to be a once and done type of person. I like to get all the parts needed and do everything in that area that is a likely wear or fail item. That is the way I work on all my items. I've already been pricing boots, seals, brakelines, etc as to me while I have it apart might as well replace it. Nothing irks me more than tearing something down and replacing the needed item only to put it back together and right away or shortly there after having to tear it apart again and replace an inexpensive gasket or seal.
When you end up doing all this and need parts, shoot me a PM, I should be able to get you all the seals and parts you'll need to do the job depending on when it is.
