Got my M109.. And the fun begins
CMXterra
Minneapolis, MN
Got some more work done.
This is all coming off.
Pioneer kit off
Drop the spare
Area clear
First bracket going on. And let me tell you. PITA. There are air tanks and wiring behind that frame rail so extra caution was had drilling the holes.
Second bracket going on
Using new fasteners did make it easier. This is as far as I have gotten on the spare tank. I have one other little thing I need to do. Relocate the parking brake cable so that the tank does not hit it.
So while taking a brake from that I moved on to something easier.
Here you see the stock position of the air intake.
New 90deg bend to get it up and away from the fender.
Mushroom back on the intake
Another view
I will see if I am motivated enough to get that brake cable moved later today. Or wait till it is back out of the 50's to work on it.
CMXterra
Minneapolis, MN
Tires are on.
You can see how taller they are here.
Getting there
Again you can see the height difference
Last set of duals about to go on
Happy truck with new shoes
Driving on radials rather than bias tires feels way different. Turning at slow speeds is about the same but these tires do not whip the steering wheel around when you let go of it. And of course my top speed is now almost 60 MPH. Now I just need a good snow to really get a feel for how much better the traction will be.
Edit: Big Thanks to Scott for getting this done.
