- 7,658
- 19,646
- 113
- Charlotte NC
.I’ve been trying for the most part of the day to bleed the brakes. I got a sprayer and filled it with a gallon of purple dot 5. Went to the master cylinder bleed nipples and connected the sprayer. Went to the rear tire and opened the bleed screw and … nothing. Cleaned out the bleed screw- no result. Went on the pass side by the torque tube and there is , what looks to me like a proportionate valve with a bleed nipple. I got fluid to come out of there. With a bunch of gunk. Bleed it until I got fresh fluid. I connected the pressure bleeder to the bleed screw on the rear wheel and I get fluid coming from the fitting by the brake caliper. I cracked the fitting by the axle open and I was also able to get fluid from there. But not from the master all the way back to the wheel.
The tm talks about a test port on the driver side. I can see it but cans acess it, do I have to have the cab up to get to it?
Any chance that the brake line to the rear axle is pinched or kinked somewhere along the frame?
