bikeman
- 502
- 113
- Ft. Bragg, NC
But not the good kind. Ended up with at least 2 bolts in my tires from a pickup last week for DanM. Thought that one of the tires was giving me problems because it's a bit worn and I had just added 1,000 lbs to the bed... (even though the tire was rated for it). Added air 3 times in the week before meeting with Dan. Still had deflation after I unloaded and brought it into the tire shop on base. They spun the tire and there she was, freebie #1, a 2" long bolt that I'd ground about half the head off of. Upon further inspection, found freebie #2, a bolt in my front right tire. Both were rusty, worn out, not the type I would have picked up anywhere else I normally run in the time frame I picked them up.
Anyways.
Anyways.
