ford381stroker
- 0
- 0
- springfield, mo
300+ miles in a Deuce makes for an extrmemly long day. The seargant told me that the Deuce I purchased was from the base and was used by the maintenance dept. This thing started right up (with a jump) and sounds great. However...
1) While driving home every so often the motor would bog and it feels as if it had a huge load on the motor. Then after a few seconds the turbo would spool back up and it was back to normal. Why? How can I fix this? Is this something that happens on all Deuces?
2) After I got to Oklahoma City, I stopped for fuel and noticed an oil leak that was not present during the hours of idling and driving before. It is dripping straight out of a hole in the bottom of the bellhousing? The motor was spotless when I picked it up and after idling but after the hour+ driving on the interstate this started. I can't seem to trace where it is coming from on the motor. Any ideas?
3) Once I got to Tulsa I noticed the clutch starting to slip when shifted into gear. I imagine its the oil leaking down that is coming out of the bellhousing but don't know. When I got home and down shifted to second gear when coming off the interstate it gripped at first, but when I was sitting at the stop light for a minute and tried to take off it started slipping in 2nd through 4th.
4) I have been unable to get my front parking lights and the headlights on at the same time. 18 wheelers flashed their lights at me all night trying to allert me that I didn't have running lights on in the front. No matter which way I turn the switches I can't seem to get them to come on.
Any advice or help would be greatly appreciated.
