GP Module Theory of Operation
doghead
4 Star General /Moderator
1,179
NY
It should be 12 ish.
It should be the same in and out of the relay(with the GPs on). If it is not, your relay is bad.
rodman68
olympia, Wa
I didnt check the input voltage I will do that next time, so I should have closer to 12 volts. I still have the resistor so some more troubleshooting will be needed I did find out my temp sensor is bad didnt know the glow plugs shouldn't cycle when warm
doghead
1,179
NY
If the input and output voltage is not the same(relay activated), that shows the relay is bad(has resistance), which is most likely bad/dirty contacts.
Complete diagnostics are covered in the -20TM.
Warthog
232
OKC, OK
This thread is NOT to be used to troubleshoot your individual system. It is a discussion of how the system works.
If you are having issues, start your own thread.
Or if you have some additions or corrections, please let me know.
antennaclimber
949
State College, PA
Just a couple of friendly hints when servicing the GP module (card).
When removing the card from the plastic housing/connector:
1. Do not use metal needle nose pliers or other metal tools to remove or insert the card. This can possibly damage components on the card.
2. Ensure that the card is NOT powered up when removing or inserting the card. This can possibly damage the card.
3. Do Not combine actions 1 and 2 when removing a card, doing this will ensure that the card is damaged.
I usually grasp the card holder with my left hand and then pull the card out with my right hand index finger and thumb, wiggle the card slightly while pulling the card out.
While the card is out, clean the card edge connectors with a pen eraser (if you can still find them) or cotton swab with electrical contact cleaner on it.
When inserting the card back in the housing , check to make sure that it is in the guide slots and is fully engaged with the metal contacts on the connector end.
This info is to help prevent a few of the failures that I have seen in the past couple of years.
Thank you.
Karl
