Ground connection near parking brake.
beltfedonly
9
Wilson/NC
My fuel gauge is not working and I was checking the 5 or 6 prong ground under the dash near the parking brake and there is nothing connected to it. Does anyone know how many if any factory connections are attached there.
cucvrus
9,919
Jonestown Pennsylvania
Fuel gauge is more then likely the ground on the drivers side rear frame section. Upper frame flange. It has a 5/16" self tapping bolt and a star washer. Remove that bolt clean the frame and reinstall. Also check and see if the wire is still attached to the fuel tank sending unit. That wire was spot welded and crimped to the sending unit assembly and I have come across a few that had the wire corroded or pulled off the sending unit. Good Luck and Happy Thanksgiving.
beltfedonly
9
Wilson/NC
Thanks guys. The fuel gauge sets at 3/4 full and doesn't move when the ignition is shut off. I am afraid that the gauge is not getting any power or is not grounded.
cucvrus
9,919
Do the dash cluster lights work? If they do the cluster is grounded somewhere. I was pointing you in the direction of the sending unit. Check and make sure that has a constant ground. The wire that hooks to the ground at the E Brake has a female spade connection. Look up under there is it floating around up there or has someone just screwed it fast to the body some where else? Good Luck. Report back. Don't leave us hanging on the diagnosis.
