08hmmwv
- 5
- 8
- Brooklyn ny
I have a quick question. My front left half shaft broke and the truck doesn’t seem to move without going into L or HL. Does the vehicle only move the front left tire in H?
Thanks, I had someone else tek me the same.Practice a little brake-throttle modulation and it'll move. If you don't know what that is as a HMMWV owner you should. It's especially handy in cases like this.
The transfer case has a (lockable) differential and both axle differentials are open. So unless the TC was shifted into L or HL, all motion/traction goes to the half-shaft & wheel with less resistance to turn....... Does the vehicle only move the front left tire in H
Which one broke if you don’t mind me asking. I didn’t know you can be rebuild it. I had a problem getting off the old one so I cut it in halfI had this same one break on me a couple weeks ago. I was coming off the trail so just removed it and drove home without it, but had to keep it in HL or my vehicle would not move either. I tried the brake throttle modulation and still couldn't get it to move other than a few feet, but in HL I was able to drive it no problem. Not driving it anymore until I rebuild my half shaft though. Mine turned out to be only my cage that broke so I'm rebuilding and not replacing.
my cage that holds it to the wheel is what broke so I simply removed the other end from the brake rotor, pulled it out then I did take the inward end apart on the trail to put that end back on the rotor just to make sure everything was held together while I drove home. Not 100% sure if that part was necessary or not, but that is how I did it. Once I took the six bolts out that hold the inner side to the rotor, the whole thing just fell out since it was no longer being supported by the wheel. I did catch it right away so I think I avoided more damage. Here is the picture of what was left of my outside cage.Which one broke if you don’t mind me asking. I didn’t know you can be rebuild it. I had a problem getting off the old one so I cut it in half. And I made the mistake of buying a 10k half shaft and I needed a 12k but hummer parts guy has good prices.
Only if she's talking about 1963 Pontiac Tempests.Just ask Marissa Tomei about posi-traction and limited slip differentials.
I’ve seen them on their website but they are not specific if they are 10 K or 12 K And if it’s shorter or the longer one that I needBuy a new set of half shafts at autozone 16058n, 16059n, 16060n are the part numbers.
Make sure you order the correct front shafts, as they are side specific because left and right are different lengths.
$114 clams per half shaft. (used to be 99).
Rockport supposedly sells parts, but why with such cheap half shafts with lifetime warranties?
ALSO... Remember that your braking will be bad as brakes connect to inner half shafts and not the wheels themselves.
You have to make sure it's a grade 12.9 metric bolt. If it's a lesser grade then it won't take that much force.Ok... looking at the torque sheet, the bolt that holds the half shaft in needs to be tightened to 57lbs.
My question is how are you doing this?
I first tried with the original bolt that came out of the old one and it snapped so I went and bought a new bolt, but it broke before getting to 57lbs as well. Either I got a bum bolt or I have me a bum torque wrench.
Material Document and Classification | G-500-M(10.9), fscm 11862 mfr ref single material response overall |
Bolts are Not 12.9....factory is 10.9...here's part of the spec :
And here is whats in the Parts manual : NSN 5306011857048 . P.N. 11516306 BOLT,MACHINE 10-1.5 X 35 MM......... 12 Ea.
Material Document and Classification G-500-M(10.9), fscm 11862 mfr ref single material response overall
That torque makes more sense for grade 10.9 than 57 flt lbs does. I just looked up the torque, then checked on the chart what grade it would need to be for that torque spec.Manual : TM9-2320-280-20-2, pg. 6-22 says: torque 48 ft lbs.
Late manual for ECV, and REV...TM9-2320-387-24-1, pg. 6-19 says 58 ft. lbs.
