HanksDeuce
- 244
- 63
- Prairieville, LA
I have a build thread with all of my modifications in it, but this breakout thread will be for those that don't normally read my build thread. It will help anyone trying to search for the necessary reading material so that they too can install an Ouverson Locker in any of their Rockwell axles (front, middle, or rear).
Materials:
- Ouverson Rockwell 16 Spline Locker [Info here]
- Axle Gasket Kit (at least the center chunk gasket)
- 0.062" stainless steel (annealed) safety wire [Link here]
- ( cotter pins for ring gear castle nuts (O'Reilly's or any parts supply house)
- A bunch of Shop Towels!
- Gear Oil
- Neoprene gloves (optional for girly men)
- Pipe
Tools:
- Hand tools to do the job (breaker bar, wrenches, large screwdriver, hammer, center punch, torque wrenches for as low as 18 ft-lb up to 150 ft-lb)
- 1 ton chainfall
- A few Chokers or chains
- A bucket
- A friend (moral support optional)
Applicable Technical Manual
- TM9-2320-361-34 [Found here]
- Chapter 10
Jargon (may or may not be correct here):
- 3rd member = Center Chunk = Differential Housing = Ginormous thing with the driveshaft going to it.
- Bull Gear = Ring Gear = That big round gear with the differential carrier halves bolted to it.
- Bottom gear = Bevel Gear = What connects to the Bull Gear.
Steps:
1) These steps basically work for installing an Ouverson Locker in the front/middle/rear axles on a M35A2. The removal steps below will work better for the middle/rear axles. It is a little more difficult to remove the front differential due to clearance below the engine's oil pan. Some folks have been known to remove the entire front axle assembly for easier access to work on the center chunk.
2) It is not necessary to jack up your deuce, but in the pictures my bobber is on jack stands because I'm changing the bearings and seals due to flood water damage from recent rescue operations in the great 2016 Louisiana Flood.
3) Follow the TM starting with Section 10-4. Drain the gear oil. Remove the driveshaft connecting to the differential assembly. Remove the axle shafts from the axle housing.
4) Remove the nuts/washers from the open area of the differential. Follow along with the pictures and place a few split lock washers on top of the nuts that are under the pinion gear housing (on both sides). As you loosen the nuts and they travel upward on the studs they will help pick up the differential housing from the axle housing. This technique will help break loose any type of gasket or sealant used between the diff/axle housings.
5) Slide your pipe between the bed and the top of the oak that runs under the bed. Wrap a small choker around the pipe and connect it to the lifting hook of the chainfall. If your chainfall has a big enough hook you can connect it directly to the pipe. Wrap a second choker or chain around the differential housing and connect it to the bottom of the chainfall. Remove the differential housing from the axle housing. BE CAREFUL! THIS THING IS HEAVY! Lower the differential housing to the ground/concrete below. Slide it out to an open area for working on it.
Pictures below for Steps 1-5.
Materials:
- Gear Oil
- Pipe
Tools:
- 1 ton chainfall
- A bucket
- Chapter 10
Steps:
