Just a reminder..... if your cucv is hard to start in both warm and cold temps, hard to start after driving, it is your fuel pressure switch. They crack and leak fuel (or not leak) from age etc. It round plastic with 2 wires and a spring clip holding it in place under the fuel filter in the Stanadyne #80 filter base for MV's only. It is part of the testing port hookup. Not in civy models. $10 fix. When they go bad it will seem like there is a leak in the fuel syster and can blow white smoke from exhaust.
I had replaced everything including having injection pump rebuilt. Even installed check valve in fuel line. Later found out the army had issued advisory on replacing them.
You can get them from Owen's Export.
