catlin
- 0
- 0
- Schenectady, NY
I'm not sure if this is the correct forum to ask this, so if there's a better place, point me in the right direction and I'll head there... I'm also not sure what the best serach parameters would be to see if this has already been covered...
I ended up with a rolling duece and a half chassis (frame, axles, and transfercase) that I ended up bobbing and putting under a 1990 Dodge Ram D250 2WD Cummins diesel truck. Pretty straight forward swap, but I'm not sure that the stock Dodge master cylinder has the displacement to handle the drum brakes on the Rockwells, does anyone have experience with that? I don't have the cash available right now to upgrade to discs (which I do plan to do in the future), so I was hoping to get the truck on the road with the stock drum brakes. I did replace the wheel cylinders and verified that the brake shoes were all in good shape.
Any help is appriciated, even if it's just direction to a more appropriate place to ask this question.
Thanks,
Greg
Thanks,
Greg
