dom1986ck30
- 1
- 8
- Haleiwa/HI
Aloha, I am doing an interior harness replacement. I have attached pics. I am stuck as I have connected the engine harness to the 'New' stock harness, from Hillbilly Wizard. It is an original harness from another CUCV of the 1984-1986 years. I have replace the ignition switch with an AC Delco part. I reworked the original ignition and it is in good shape, I believe. I have ran most of the interior wiring to their respected places. I am focusing on starting right now, then I will complete the auxiliary and other interior wirings. The connection to the engine harness seems fine. I connected the starter relay, (see pic.) I have referenced from the pics I took prior to the project. The reason I replaced new and installed the starter relay is because this all happened when I started a fire and now I have new batteries. 880 amp/1080cc amps. optima batteries. All terminals replaced new. I feel like I have connected the engine compartment back to the way it was and am now not understanding why I do not get a light on my tester when I touch anything on the replaced interior harness fuse block. Please help... Also, just to be clear, I have the T.M. circuit diagrams. All of them... Any and all help is appreciated... I miss driving this thing
