Hawker 6TAGM battery
doghead
4 Star General /Moderator
1,174
NY
Dave and Debbie Lewis, 393 North Collingwood Ave, Syracuse Ny 13206.
315-437-9075 They are an Interstate dealer in Syracuse. They should have 6TLs in stock.
68impalass
camillus (Syracuse), ny
6tagm
Yes, tried that also. When I got the 09 4 years ago both batteries were dead. I slowly bought them up over a few days and they have been fine. Now I see corrosion coming up from the "vents" at the top of the battery. The charging system is fine as it puts out 14.7 volts. I think it's time.
Keith_J
1,316
Schertz TX
$370 ? Install a pair of group 31s in it, take the $540 you saved and buy a quarter ounce of gold. When the group 31s need replacing, the gold will have enough value to easily replace the batteries with another pair of group 31s.
AGMs may not have the cranking current you need. They CLAIM to have the cranking current yet don't specify. Caveat emptor.
Ferroequinologist
Resident railroad expert
736
Liberty Hill, SC
I put 4 of the AGM batteries in the 5ton , and I could crank it for a week if I wanted to. I am extreamely happy with those batteries HOWEVER, I'm not $370 each happy with them...
Newcleo
USA
To purchase the original battery , here is the ordering page : http://www.hawkeraplus.com/order.htm but before you get to spend alot of money on brand new batteries, read the army manual (http://www.hawkeraplus.com/pdf/TB-9-6140-252-13.pdf) and use your meter, you maybe able to revive your battery. They are design to be revived even when the voltage goes down to 2.4 Volt DC. I put mine on trickle charge using a solar panel. It took a while and I was able to get the Voltage back to 12.5Vdc ( equivalent to a 60% State Of Charge) from an original 10.1Vdc.
Sal
