cmroles
- 0
- 0
- Phoenix, AZ
Well...
I solved one big problem today. Thanks to all the info I found by searching this site I tracked down a broken ground wire at the Passenger Side headlight connector and successfully replaced it.
For anyone else who may have a similar problem, here are the symptoms I had:
1. Passenger-side headlight functions but very dimly
2. When headlights were ON the right turn-signal indicator on the dash would be faintly illuminated
3. When the right turn-signal was actually operating the headlight would blink with the signal....
After inspecting the wiring I also found that the 10ga ground wire between the Body and Chassis was in really bad shape. The insulation had fallen off (see pic) and the wire was fairly corroded. I built a new harness using some watertight ring-terminals and some 10ga and 14ga wire. I also cleaned up the ground spots on the chassis and body and applied some dialectric grease to keep them from getting rusty.
Now: The remaining "turn-signal" problem I have is that the Left signal illuminates whenever the brake pedal is pressed. The signals all work as they should (front / rear blink when signal engaged), but whenever I hit the brakes the left ones lite up. I've been through the wiring diagrams and I'm not seeing any common point between brake-light circuits and turn signals. Is there something I'm missing?
