John B.
- 12
- 3
- Pennsylvania
Thank you for adding me to the group! I just recently got my first MV. It's a 1968 M35A2 multi fuel with a winch. I'm told that this particular truck was used in the New Jersey Pineberons as a recovery truck for people who got their 4x4s stuck. I'm also told that it has a cult following in certain circles that remember this truck and hate the idea of it being changed in any way. If anyone recognizes this truck I would like to keep it's memory alive. I would like any photos or stories about it so I can document them and save them. I don't want to loose it's history military or civilian. That said it's in rough shape body wise. I want to restore this truck back to it's original military look. It runs strong, has good axeles, a good transmission, and good transfer case. The frame is solid and doesn't show any signs of stress damage like loose crossmembers or broken mounts. Everything works mechanically. I have not tried the winch yet. I should add that I'm a heavy diesel mechanic with 20 years experience and I've researched the M35A2 extensively on this sight and all over the internet. I'm going to do a complete over haul of the brake system, all hubs, and wheel bearings. Form follows function and the single circuit brake system is this trucks most frightening weak point. I've read about the hydro-max/hydro-boost upgrade and that's definitely an in the future project. I need to find tires for it too. All ten of them are dry rotted BADLY! I don't have a big budget right now but tires are needed so I can drive it around and after the brake overhaul that's my next big expense. Then it's on to the body work.
