help... 1008 and 1009 keep SNAPPING off starter studs!!!
bruno_rs
chester, nj
RE: Re: RE: Re: RE: Help M1008 and M1009
surpdlr, the weasel looks like ALOT of fun. good luck and be well. thanks again for your help.
Michael
24
Fulton, MS
The AC=13G is the original equipment plug that is listed in the manual but it is obsolete. It was replaced by the AC-60G. You can go to GM part direct and plug in any 6.2 or 6.5 of any year and it will recommend the AC-60G. It is non swelling and current limited. While it is true that the 60g is not putting the exact same load across the voltage dropping resistor as the 13g, I believe that the current limiting feature of these plugs compensate for this.
beaubeau
Salisbury,N.H. 03268
BrunoRs Be sure to put that front bracket on with the starter. I have seen where instead of Studs breaking, the Casting would break off. I have had to go as far as having to Weld a starter in place because the casting broke and could not use a starter bolt again. Also, when working with Glo Plugs, be sure they all work, because they Cycle and if one is Bad. it wont cycle. Good Luck, Phil
bruno_rs
chester, nj
Re: RE: Re: RE: Re: RE: Help M1008 and M1009
thanks phil, i'll make sure i do what you suggest. i'm new to diesels... it may sound stupid but what is the best way to test individual glow plugs... could you elaborate? so glad i found this site, you guys really know your stuff... thanks again. have a good one.
surpdlr
PA
pa.rich said:
About the bolts . Are they studs with nuts on them? or just bolts? Are they grade 8? Anyways that gear must be going into the flywheel too far, hence the shims.What a way to find out tho.
They are listed on my web site:
01-227-9085 BOLT STARTER CUCV $2.50
http://www.flmv.net/FLMV-CUCV.htm
