Foreverunstopable
- 0
- 0
Hi guys. I have a bit of a problem. I got a custom truck for my birthday. Its a 74 C-65 w/ stock engine 366 Tall-deck, stock trans CL280V but was converted to 4x4. After researching the axles are the Rockwell front loader type on the early deuce. Here is my problem. The transfer case is most likely from the same truck and I need to either rebuild it or get another one. The front output to the front axle will turn with the transfer case going forwards. In reverse it locks up. I took out the drive shaft and I and spin the output counter-clockwise by hand, you feel a little "clicking." I try to then turn it clockwise and it engages with the transfer case. What do you suggest. Attached are pictures of the transfer case. There are two sets of visible numbers
F173 on a flange to the right of the rear end on the transfer case
GM1
2275827
H53 on the back near the middle stamped upside-down
Any help would be greatly appreciated
GM1
2275827
