cessnatwin
- 30
- 0
- seminole/florida
get on the phone with saturn surplus or memphis equipment tell them you need ALL the seals, it is the very inner little seal that leaks, DO NOT buy zipper boots, because you will be in there and can slip a complete boot on and seal it up, it is not your wheel bearing seals that are leaking it is the inner shaft seal. NO BIG DEAL! When you get home the parts will be waiting for you. your wheel bearings will be fine. DONT pull anything apart or remove it unless your gonna fix it, its waisted effort. JUST FILL IT UP AND GO!
