- 10,861
- 747
- 113
- Front Royal, VA
Project for next year is to build and design a S-280 radio shelter that would be my ham shack, that could be a semi-permanent emplacement here, but could also be mounted in the future to a M923/5 series truck for bringing to shows so I could run my ham gear on site. It will also be a camper (radios and bench on one side, two bunks and storage on the other).
Was interested in hearing your opinions on what radios should be in the radio shelter, based on the needs that I would like to fill:
1. I'd prefer many of the radios to be military rack mount type, but will substitute regular military radios, or commercial radios, if no suitable rack mount mil-spec radios exist for the task (or are too expensive for most buyers)
2. RX coverage must be full spectrum, from VLF to microwave.
3. TX coverage must be most of the common ham bands, to include: 160 meters, 80 m, 40m, 20m, 15m, 12m, 10m, 6m, 2m, 70cm, and 33cm. There are a few in there that I didn't cover, but these are the ones I would like coverage on.
4. No data/RTTY is needed for the installation at this time - if I decide to do that later, I can always install a rack-mount computer PC and have the data run through that to RX/TX, to eliminate the need for a stand-alone teletype, etc.
5. Power supply? I'd like the capability to run at least one TX and one RX at one time, with 100% redundancy. Output would be 100 watts minimum average TX, but possibly up to legal max of 1KW if required.
6. Computer - I'd like to install a rack-mount PC in there, along with a suitable monitor. Some rack mount jobs are expensive, so I'd like some input of how I can make it work, without having to win the lottery.
7. Antenna types would be dependent on the capabilities of the radios, but I would like input as to what antennas you feel would be able to cover the maximum number of bands, so I don't need 100 antennas around the shelter.
8. Vintage of the radios and gear, I would like to be late 1950s to 1980s. Any newer and cost is prohibitive, or radios are too rare. Any older and the radios have issues such as lack of selectivity, drifting or RF leaking issues, obsolete parts availability, etc.
Thanks for your help and opinions.
