Help...on road now and truck wont start
I_Publius
Prosper, TX
My truck was running fine and hour ago. I took her about 20 miles from the house, stopped and went inside to talk, came back 30 minutes later and now she will not start.
I borrowed a power supply to jumpstart it, but that has not helped, yet.
Anything else I should be looking at?
I_Publius
Prosper, TX
I am going to let it charge for 15 mins instead of expecting it to start immediately. It might be that the batteries aren't charging.
I_Publius
Prosper, TX
Seem to have fuel in racor spin on filter and i just filled it up last weekend.
Orange wire..I'll check.
Good thing is that i am in front of a diesel shop, so they will probably help if needed.
Uggggg
I_Publius
Prosper, TX
After letting it charge for 20 minutes, it started right up. I am going to guess it is an alternator or one of those GEN bulb issues. Anything else I should look at?
Thank you for your suggestions, by the way. I will keep those in my memory bank and remember them if I ever have trouble like this again. :)
I_Publius
Prosper, TX
I am currently driving home and just passed by my favorite AutoZone. ;)
They hooked up their alternator and battery tester see if it would pass and it did, so once I get home I will start looking for in depth with my voltmeter.
AceHigh
30
Princeton WV Lake City FL
I had the same symptom on mine and found it was the IP failing. It would start fine, but once I turned it off and tried to start it within one hour it would not start. A temp fix for this, if yours is having the same problem, is to pour cool water on the IP, it should start. If that is the case you would need a new IP. Best of luck on it.
Warthog
232
OKC, OK
Did you ever get the GEN lights working on a consistant basis?
Warthog
232
OKC, OK
Just remembered we did the Rosscommon 12v conversion. You might add that to your signature line so everyone will know...... ;-)
Check the battery voltage with the truck off and running.
Triple C
NAPOLEON MO
I can not tell if the motor turned over well when you turned the key or if you had to add a jumper battery to get enough juice. If you did have to add a battery, and your system is generating then I would start by checking all your battery connections first.
I_Publius
Prosper, TX
It was attempting to turn over, but never did. During that time of trying to get it to run, the batteries drained more. At that point I hooked up a battery charger for about 20 minutes and after doing so it turned over and started.
I have two group 34 batteries I purchased from a green and white battery manufacture here in Dallas. Those were purchased in August, so they should be fairly fresh.
Since I have a 12 V system, I only have one alternator and only one generator light bulb that i should need. The GRN II bulb Seems to be working.
I am going to look at my battery connections and make sure they are all tightened down properly.
