USAWEAPON777
- 1
- 18
- Orwigsburg,Pa
hey guys, well I have an oil that is well frankly slowly driving me insane. When I first got my m1008 it did'nt have any leaks. after about a year I saw some slight dripping from the pan. So i pulled the pan and redid the rtv and put it all together and no more leak. A couple of months later I had a leak again. I was pretty bummed but figured this time it was the rear main seal because it was dripping from the bellhousing cover and I also near the engine crossmember but I figured that was from the 2 stripped oil pan bolts I discovered. So I ordered everything I needed and this past weekend tore into it. Pulled the pan, replaced the rear main seal, fixed the stripped bolt holes. replaced the gasket and used a little rtv, and put it all together. What I found is that the truck is still leaking decently out of the front near the pan
. Pretty freakin annoying when I spent most of my weekend on it. However, I can't see the oil coming from the pan it looks almost above it by the balancer. So now I'm thinking that I've been wasting my time and the front crank seal is to blame.
What do you guys think? Also, how hard would you judge the job compared to the rear main seal? Also could it be possible that the fan is blowing so much air in the engine compartment that it was pushing the oil so some of it would drip from the bellhousing cover? I know I wrote a lot sorry about that. Any help appreciated.
![Banging Head aua aua](https://www.steelsoldiers.com/images/smilies/icon_smile_banghead_125.gif)
