jrcampbe
- 0
- 1
- Minneapolis, MN
Hi everyone, I just learned about this great site and have been reading lots of good stuff in the FAQs and old posts.
I just bought an MEP002a generator and scored what I think is an M939 77-gallon ful tank for $63 that I intend to use as an auxillary fuel tank for the generator. The tank looks like new old stock or possibly refurbished:
http://gsaauctions.gov/clsauctions/regn8/81QSCI12150005.JPG
I'm trying to understand what I'll need to do to make this work. It looks like the tank is missing the fuel level sensor??? I am assuming two of the small ports are for fuel and return fuel. What are the other two with little elbows on them? One must be the vent, but I really don't know what I'm looking at. Can you help me understand:
1. What are the different ports on this tank?
2. Will this work with an external fuel pump, or does it need an in-tank electric pump?
3. What size fuel line and connectors do I need?
4. Is that taped-over hole for the fuel level sending unit, and where might I be able to find that part?
5. How should this be vented for what may be fairly low consumption? Is there a check valve installed already internally? Do I need parts for venting/breathing and are they water proof?
6. Can I leave the return line connector plugged?
7. Do you know where I can find a technical document explaining these things?
8. Do you know where I can get a compatible fuel gauge and cable with the proper connectors?
Thanks in advance, guys! I'm very excited about the generator as it only has 12 hours and looks like it still has the rebuild depot manifest on it! I'll post about my progress getting it running if anyone cares (at leas I have the TMs for the generator).
Jim
Jim
