Blood_of_Tyrants
- 10
- 38
- Lebanon, TN
Like many of you, I have bought MVs from GL and GSA with weak or dead batteries. For a battery that won't take a charge at all, there is little you can do. But if the battery is weak and just won't hold a deep charge, there is a little trick you can try. Go to any grocery store or drug store and get a small box of Epsom salts. Heat up about a quart of distilled water hot enough to completely dissolve about 10 heaping teaspoons of Epsom salts in it.
Now, pour out about half the acid then refill the battery with the Epsom salt solution. Charge it as you normally would and you are done.
I was skeptical about this until I tried it about 7 months ago in a 6TL and it brought it back to life and it is still cranking.
