- 849
- 1,740
- 93
- N. Central Idaho
Just put my dash panel in with new air gage, air hose to it and to the control of the front hubs. Started and at 60 PSI buzzer cut off. But the pressure continued tp build until it pegged above 120. Went to the TMs, bled the pressure down and adjusted governor as specified. Ended up turning the adjustment screw out (counterclockwise as specified) a total of 3 to 4 turns until it ran out of adjustment and the needle still pegs out.
Since the gage reads 60 when the low air buzzer cuts off I suspect it is correct. The old gage read 120 every time I ran it including earlier this week with the old parts still in. I'm not willing to pull the panel again to sub it in unless I have to.
Air governors are inexpensive, but before I replace it is there anything else I should look at/do? Seems strange this just suddenly started when I installed new parts.
