The OP
did a fine job. No doubt!
There are many ways to skin this cat. I looked at it for days and then I
decided to do things a little differently for my 5 TON. I considered the space and
laws and decided I should go w/ a much wider hitch assembly
to try to help prevent beheading folks who might rear end me and
to make a decent way to carry safely a Medium TowBar.
I am not perfect, nor are the law(s) but here is what I found to work very well
trying to take all issues into consideration.
My way is not perfect,
it is just another way.
You can buy the main crossbar you see in my pics online, all welded up,
then just add my drops and gussets and sometimes adjust other parts
and then just weld things up and paint!. I used a certified welder just to make sure
I was doing things per code / the law to the best I can, trying to not leave any
stones unturned.
(Insert Shameless Plug Here) ;
FWIW, I sell the 4 brackets you see below. I do not sell the cross bar or hardware
nor the towbar or it's holder or hardware et al. My parts are all water jet precision cut and sent to you,
so you can have a certified welder weld / fit it all up and use it off road only, and
under 1 MPH MAX! (there, I appeased the law-gods)
HA! (
Personally I have abused mine tremendously and no failures anywhere on it! )
NOTE the added TowBar and it's bracketry and U-Bolts I made so I have a
Towbar with me always wherever I go for me or others.
View attachment 519861 View attachment 519862 View attachment 519863 View attachment 519864
