Here's my situation:
New HMMWV owner with more than one trailer wired for std 12V. Same trailers are used routinely behind my F150 and other vehicles (of friends who borrow them).
I'm trying to build a solution that does not involve swapping bulbs on the trailer, so here's what I think might work - all you EE's out there tell me if it won't please.
Three primary circuits go to the trailer - which equates to the elements on the bulbs I need to energize: Parking, Left Turn and Right Turn (the brake light signal is carried on the R/L Turn circuits). These are min legal requirements for trailers in Tx.
The general concept is to use signals from each of thee three 24V circuits (via taps) to energize relays, through which 12V - provided by a DC/DC 20A converter - will be switched to my trailer receptacle. So, I tap the appropriate wires on the HMMWV and these taps will energize the relays only when they are powered - turning on parking lights, turn signals, etc. When the coils are energized, the 12V coming from the converter is switched to the trailer lights. I believe there will be plenty of room in the battery compartment to mount the relays and converter on to a board and put together a simple harness.
R/L Turn (and brake light) circuits: As these are mostly intermittent, light duty 12v mini relays (see pic) will work on each of the R/L Turn circuits. They're plentiful in my parts bins or the local wrecking yard, too. Unless these circuits are closed for extended periods of time, the 12V relays will do fine without overheating. And it's a great use of those mini relays I've been saving.
Parking: Two 12v mini relays wired in series, energized by 24v, resulting in 12v to each relay. One relay will be used for the rear parking lights and the other for side clearance lamps on the trailer, again, using 12V from the converter.
Thoughts? Anyone done this before?
