So far I can't seem to find anything about any door binding issues on the hmmwv.. so here's my problem.
I had a two man soft top setup and put hard doors on. The driver side felt really springy like it was binding on something when I tried to close it. I had to slam it pretty good to get it shut. The passenger door was a little springy but not bad. Only had to "kinda" slam it to shut. So I chalked it up to the doors not liking the soft top. I also took the drivers door completely apart to check if the aluminum guides were bent. But they werent.
Now I put on an helmet top and now the passenger doors front and rear shut perfectly. The drivers front shuts pretty good. Only a minimal amount of binding if any but the drivers rear is pretty bad. It seems to be binding pretty bad and have to put some force into it to get it to shut.
The driver rear hinge seems like it needs to be shimmed at the body to make it not bind and the seals to mate up to the body. But I'm not entirely sure.
The helmet top fits good and I checked all gaps and measurements multiple times so I don't think that's a problem.
Is this something that's common hmmwvs? Or did I just get a weird hmmwv? Aside from the weird door fitting issue it runs, drives, and tracks great. So I don't think it's been hit or ran into by anything but who knows.
Any info or theories on this? Thanks!
ZB
ZB
