Hmmwv rims
onewoodsrider
Gig harbor,WA
Did they make different rims for bias tires versus radial ? Are they the same rim? Any idea what a fair price would be for the 12bolt rim with run flat. Was offered 4 rims with runflats for 250.00. The rims need new o-rings and paint as they are not in the best of shape. Any help would be great.
WILDBOY6X6
Newark ca
wheel
HI no the bias is a diff wheel less wheel half studs than other 1.and yes the price sounds good for the ones u found too. Beleave or not the O rings for a 5 ton air cleaner are very close fit I have used hmmwv ones for them.
WILDBOY6X6
Newark ca
tires/wheels
330789125901
HI LOOK UP THIS ITEM # on ebay it is a set of 4 mounted and ready to use he has 2 sets,but there in so cal .
1,174
This has all been covered before(in great detail), I suggest you search more.
You can put bias and radials on the latest style 12 and 24 bolt rims.
You can only put bias tires on the old 8 bolt rims.
