February 24th, 2008.
DMUCHOW:
My M35A2 from 1971 has the same button set up as above, but there is a two note airhorn mounted on the inner right fender and connected to the airline splitter "T" up on the firewall in front of the passenger. The horn is operated by an integral solenoid that opens the air valve on the horn body. Desert Deuce has them NOS or reconditioned, they're military and not quite like civillian motor truck horns in their pitches, I suspect it had something to do with European traffic regulations. When I got my deuce from a GI up at Fort Carson,CO, it was missing the lower horn bell and did not sound much different then a 1970's Honda Civic electric horn, but once replaced, the horn is loud enought to scare the S--t out of the average Texas airhead driver and make them reconsider their suicidal notions and driving habits.If you cannot immediately replace the airhorn, you will need to temporarily cap or plug the airline, as you won't have airbrakes otherwise. Good luck gentlemen, and yes, the switch design is no different then a 1951 Ford F-6, but more subject to weather and corrosion.
I remain, As Always Sirs,
Indebted for the Insights,
Sincerely,
Kyle F. McGrogan
1963 Swiss Mercedes Benz S404.114 Unimog
1971 Kaiser Jeep M35A2 Wo/W "Saddam's Nightmare" Vietnam and Desert Storm Veteran Deuce Truck.
