JRBAMATEX
- 1
- 0
- Haslet, TX
Does anyone have a good idea how to change this hose. I am going to replace all my hose clamps with T-Bolt type clamps and plan to replace all my hoses and belts at the same time. As I was looking things over and getting measurements for the new T-Bolt hose clamps I saw this and said this is going to be a trick to change. At first glance I think the easy way would be to take those little manifold looking things off of the top of the head so that I can get in there and replace the hoses. Otherwise I can’t see how you would get the old ones off or the new ones on.
Also, what about the compressor belt? There’s no adjuster. How do you get that belt of and a new one on? Do you just loosen the bolts on the compressor pulley and slide it off then reverse the process to put it back together or is it trickier than that?
