How do you Wire a Dash Light Bulb?
Mgood
kansas
That makes sense. I was wondering how to use solder and still have the spring able to compress. But I guess that if you solder the wire to the tee button separate from the spring that it will still allow the spring to compress. Thanks for your help. I will let you know how it works.
JohnFire
Pottsville, PA
yep through the spring and soldered to the tee button would be your best bet. good luck cause sometimes they are a pain to hold solder and get the wire to stay in while trying to do it all.
