How long should glow plugs last??
kcbbqguru
kansas city
Does anyone know how long a set of glow plugs should last before needing to be replaced? I have had a hard time starting the past few days with the cold snap. I looked all over forum, but hasn't found anything, thanks
doghead
4 Star General /Moderator
1,172
NY
No answer to that.
Too many variables.
479
Madison, WI
Some questions that could help narrow down an approximate answer to your question:
Are you running a totally stock GP system? Are there mods or repairs done to the system? Which plugs do you have in it?
PS- I like that Doghead and Warthog are playing doppelganger. :goodjob:
Hasdrubal
Vancouver BC
I've been running AC60's with a manual push button system for 10 years. I get a minimum of 4 years out of them , some have lasted as long as 6. They're easy to test, less than 5 minutes. Just replace the faulty ones, no need to replace all 8. When its really cold you need a longer burn cycle, even then mine take a few seconds of cranking. At warmer temps engine fires immediately.
doghead
1,172
NY
With a multi-meter. You measure resistance(ohms). 1-3 ohms.
Covered in the -20TM.
