How long to change out a T-case?
ida34
35
Dexter, MI
Oil can is coming up this weekend to change out his T-case. From people that have done it, how long did it take you to remove and install? Looking at things I figure about three hours to take out and probably four or five to install. It looks like it should take considerably less but I factor in Murphy in my equations. The engine I am working on now had Murphy all over it. Approx 15 broken off bolts and studs to fix. I think the last guy to rebuild really over torqued everything then rust set in. Murphy will not be denied.
Any input on time required to complete the job would be appreciated.
Thanks
Chuck
ken
26
Houston Texas
The worst part of the job was the E-bake cable. I'd drown the adjusting nut in penetrating oil at least a day before i started. But i did it in 4 1/2 hours by myself with a chain fall through the floor. Good luck!
BFR
Rocket Surgeon
2,330
42
North Georgia
I'd say clinto & I took mine out & had the replacement back in (w/o the airlines) in about 6 counting trips to wendy's & scrounging for bolts at home depot. I had another couple of hours in the airlines. while mine was out clinto replaced the output seal in the tranny and I swapped my old parking brake onto the new case.
BFR
Rocket Surgeon
2,330
42
North Georgia
I would also try to park the truck where clearance around the spare is good as that seemed to be the best route of getting the cases in/out.
ida34
35
Dexter, MI
Thanks for the respones. The ebrake is not in the equation. It is already removed and the front and rear driveshaft are already removed. It so happens that the spare side is going to afford the most amount of room to drag it out. We will post results later. I will try to get some pics but I will probably not be home for much of the stuff.
