notso
- 0
- 0
- Birmingham, AL
Just got a '35A2 andnhave a couple of questions on some possible leaks on the truck.
There appears to be a slight leak on the passengers side near the center of the engine block from behind the exhaust manifold.
There also appears to be a very small leak on the drivers side under the filters mounted in the middle of the engine.
Niether one seems to be major, and both seem to be oil, not fuel. The passengers side may be from a hose I think, but I cant get my head craned around to check.
The engine oil is still at full, and I will monitor the level. There only is a drop or two that actually made it to the ground but I guess this is considered a class 3 leak?
Sorry if this is covered elsewhere. I am still working through the -20 and -30 TMs.
