84cucv1ton
- 0
- 36
- New Jersey
MC is new. thought that was my problem... never had a problem like this.. not sure where to start. as alwys thanks
That was the problem in my M1009 when I picked it up. Had no power steering and barely any brakes. Filling the power steering reservoir with fluid fixed both problems but the fluid drained slowly from the steering box. My truck is in FL with all the rest of my stuff but my dad says the box may have stopped leaking. I can't wait to get it up here (along with my dog and all my stuff) and start working on it.Verify Power Steering fluid level. As it gets low it will pulsate while steering and braking as the Power Steering fluid gets low. Try to find and repair the leak if this resolves your problem.
yes!! you will never be able to get all of the air out in car, the pedal will not do the full stroke of the mc like bench bleeding.do you really need to bench bleed?
