baja_power
- 0
- 0
- Marysville Ohio
Are the front and rear hubs the same and interchangeable?
I had a bad wheel bearing in the back, replaced it. All is fine...
Had a front go too. But this one took some other parts with it. Including a hub.
Ive notices the hubs are drilled and Tapped on both sides. By flipping the drum around and pressing and flipping out the studs, can a rear hub be used in the front?
Attached are photos of the front hub. Note the drilled holes on both sides.
