The engine, trans and transfer will work just fine. The transfer case should be the NP242 which will be the same as what is in the Humvees with that transfer case, except that the tail shaft extension is different, because the Hummer didn't use the speedo gear and cable like the Humvee did. It has a sensor so the housing needs to be changed out and the gear placed on the shaft so the speedo gear has something to be turned by. The trans is the easiest part. No modifications needed. The engine will fit except for the starter, injector pump, turbo boost controller, injector lines, water pump, fan and clutch, power steering pump, fuel lift pump and it's oprating shaft as well as the plate it mounts through. and all of the brackets on the front of the engine for the mil generator and power steering. Wire harness for the engine ofcourse as well as all sensors, plus the water crossover and any other civi crap like the CDR Valve and little things like that.
