hotcorner216
- 0
- 1
- Southern California
Well this all started about 5 months ago, T case started leaking quite a bit from the front output shaft seal, so I changed it, no leak for about 3 months, then it started leaking a again, I let the truck sit for about a month till I had time to change it, Changed it again with a different seal from a different part store, lightly hand sanded the yoke to make sure it was smooth and 2-3 weeks later started leaking again. Since the initial leak there was a humming noise coming from the T case only when it was leaking, I topped it off and it would hum on and off, T case is now humming again. T case was rebuilt by previous owners mechanic about 2 years ago. I do engage 4 hi and low at least once a month on a hill behind my home just to have it engaged and get the parts moving, always engages with not problem...
Any advise on fixing this issue?
besides bathing it in silicone...lol
