Hummvee tires/lift kits, 880 Dodge
MatthewH
Boyne City Mi
I had thought of that, but it sits pretty high as it is, and i use the truck for my welding buisness, so i didn't want the truck way up in the air. Also, there is a suprising amount of room in the fenders, and honestly, i don't do much hardcore offroading, so i feel it will work alright.
wildbilly1760
Pottersdale, PA
That makes an awesome welding truck. What kind of welder do you have in it. Maybe show some pics of your set up. I am a welder at a coal company. Always wanted to go out on my own, and start a small business. bill
ironbulance
nomansland
I would like to put hummvee tires on my newly aquired M887. I know that you need a 2" spacer to clear the tie rods, but not sure about the suspension lift. I have heard that an add a leaf will clear them, but also heard they will rub when the wheel is fully locked. What size lift do i need to clear brand new 37" tires without them rubbing the fenders at all?
Thanks in advance
MatthewH
I did a 4" lift still had to trim front fenders just a bit near bottom cuz when I got the body twisting off road it was hitting in a few places, I have 37"humvee tires on it with a set of aftermarket 10 " wide rims awesome traction
MatthewH
Boyne City Mi
I guess i forgot to post an update, with pics, that it is possible to mount 37" tires without a lift kit and only minor fender trimming. However, i did have to change to a later model year steering setup. Guess i'll have to get on that.
ironbulance
nomansland
ya I did a power steering upgrade, I went to local junkyard and found a donor truck and got everything def needed with these big tires:jumpin:
rangernut0901180
Mansfield, OH
Will the HMMWV wheels fit on an 88 Ford F250 4x4 8lug I have a set of Michelin XL's on it now (WITH NO LIFT) but I am having Issues locating a Replacement set of the XL's
Milt51
Douglas WY
A little more specific on the later steering setup?
MatthewH
Boyne City Mi
For power steering, you'll need to find a W series dodge truck, up to '93 with a 318ci motor. You'll need the pump and any brackets associated, lines, gearbox, drag link, and the steering shaft/column. If you notice earlier in the post, i made a shaft so i could use the newer box with the older column, otherwise you'll have to use the newer column, or an aftermarket steering shaft.
Blythewoodjoe
56
Blythewood, SC
I have found this thread to be very helpful. I purchased a set of wagon wheels last week that I had planned to use on my M886. After putting them on just to see what they look like, I am having second thoughts. My brother thought they looked too big and I tend to agree. We use the truck for camping and playing and I guess lifting it will make it harder to use. I'm not sure what I want to do. Anyway here are a few pictures. I might just put the wheel in the classified. I know if I get rid of them I will regret it. You can't go wrong with big tires. I got 4 good wheels and one is burned. I don't think it got very hot but it messed the paint up pretty good. I don't mind trimming the fenders a little but the drag link is the problem. Any more threads out there with other options?
Joe
