Spagman
- 1
- 1
- Branchburg, NJ
Hello forum members,
I started servicing the cooling system on a M1025A2 equipped with a NA 6.5L that was purchased this summer and ran into an issue with coolant slowly leaking from a small hole in the driver side rear of the engine block just above the oil filter lines. This hole is between the rearmost threaded coolant plug and the transmission bell housing. When I compare the engine in the 1025A2 to the one in my 1045A2 I notice that the 1045A2 has a small plug installed in this same hole that looks like a miniature press fit freeze plug. The 1025A2 engine has what appears to be a short piece of pipe pressed into the same hole, but it is open straight through into the block. I searched the web to see if the plug for this hole is part of a standard 6.5L freeze plug set, but had no luck. Attached is a picture that I took of the 1025A2 engine with the end of a small screwdriver pointing to the hole with the protruding pipe end sticking out.
Appreciate any help you can provide on why the 1025 set up is different and where I can get the proper plug to seal this hole. Thank you.
