Humvee trailering set up
Action
1,556
East Tennessee
Open the claw, set trailer in, close, add chains and brake cable and pin, plug in the trailer to the receptacle, check lights. or something along those lines. release trailer brakes.
Bucho
Phoenix, AZ
It does but it is based on a 24 volt military plug. You could not not just hook up any trailer. If you wanted to tow just a run of the mill trailer you would have to rewire it. Also there is no ball hitch on these, it is a pintle hitch.
Wire Fox
161
Indianapolis, Indiana
I don't think there's an official adapter. I've seen several on eBay that look decently built, but I don't know what their true capacities might be. It might be possible to purchase and install an AM General H1 hitch receiver, but you might have to remove your pintle hitch to install it.
ryanruck
46
Cincinnati, OH
The H1 hitch will install no problem. You must have the airlift bumper and the pintle must be removed. Only "modification" was having to drill the body brackets to mount the outside hitch brackets to.
It's an impressive mount that doesn't just mount to the bumper and body brackets, it also has braces that attach it to the rear lower control arm mounts.
Pic from about a year ago when I was nearly wrapped up on the install.
All parts purchased from HummerPartsGuy but you might find them at other places:
6008114 - RECEIVER, TRAILER HITCH
6007689B5 - BRACE, TRAILER HITCH (RH)
6007688B5 - BRACE, TRAILER HITCH (LH)
6007931 - BRACKET, HITCH (RH)
6007905 - BRACKET, HITCH (LH)
6018756 - BRACKET, TRAILER HITCH (RH)
6018757 - BRACKET, TRAILER HITCH (LH)
You'll have to hunt down some Grade 8 bolts, washers, and nuts for everything.
Wrbrackett
Atkinsion nh 03811
Thank you for everyone's help.i really appreciate it.so I should be able to find the same boat trailer bulbs in 24 volt?
I will double check I think my trailer has leds,not sure if that makes a difference.
Sent from my iPhone using Tapatalk Pro
infidel got me
34
Newberry, Florida
A simple 4 wire trailer plug can be tapped in to existing taillight wiring at the rear of the truck- cost around 6 bucks. Evolve from the Amish boat lighting (24 VOLT) bulbs and go led.....
TucsonVTXF
Tucson AZ
the military plug in that setup is other side of what you need any bulbs on your boat trailer will need to be led bulbs that can handle 24v or 24v bulbs
