I ordered a Vernier type hand throttle cable today. It is the kind that you can pull out or twist for fine adjustment and when you press the center red button it releases.
What I am going to try to do is drill a hole through the out side part of handle casing and run a second cable through the center of the red release button. On the end of the cable will be a crimp and spring.
This second cable will be routed under the dash and connected to the brake pedal.
When the brake pedal is pressed it pulls the cable which pulls the red button releasing the hand throttle. I am going to try and attach the second cable's housing to the handle you pull. This way pulling the throttle out doesn't pull the brake cable.
Any one ever seen some thing like this?
