- 3,021
- 221
- 63
- eldersburg maryland
several people have asked about my power steering so here is the basic info. you need to be capable of fabricating the bits needed to install it.
the best fit i have found is a saginaw 710 box from mid 80's internationals. this is a dual piston box and is very common. used with a 800 series upper column, and a 800 series steering wheel ( 18" od ) or you can make a column from your old box parts, and a five ton pump then all you need to fab is the inter connect shaft and lines. a mounting and bending template is available if you really need one. the top bolt goes above the frame , i added a plate above the frame at the same time i filled in the cutout for the old box. i had a piece of 3/8" plate press bent to match the inside radius of the frame, you can see it in the 2nd picture. you need to reshape the 710 pittman arm and rotate the drag link 90 deg and make it 1/2" longer but it is the same taper as the steering arm so that is a plus. next time i will thread the outside of the drag link and put an adjuster on it, more legal and gives some adjustment. you can palm steer even sitting still with the smaller steering wheel.
updated info on 02/15
